My brother Bernie came over and helped with fuel tank sealing work. In the first session we riveted and sealed in the tank skin stiffeners, the filler neck, the drain fitting and one rib. In a second session we riveted and sealed in several more ribs, see image 1 and 2. Also in the morning I finished the final steps on the wing storage stand. The leading edge cut outs on one side of the stand and the notches to hold the spars on the other end of the stand had to be cut as well as the spar support end needed a height adjustment, see image 3.
